Discussion topic: qbox
This message was authored by: lg28
Message posted on 03 Sep 2025 09:34 PM
qbox
h i cant get sky cinema watch on sky box x watch via sky x satelite signal tick i cant get any sky cinema i vavnt been able to watch sky cinema im elderly/disabled please help kind regards capinner ps skymini box is hot on the top.
Find out more
Message posted on 04 Sep 2025 04:15 AM
Re: qbox
Presuming that you've got the Sky Cinema add-on what's happening when you try to view channel 301 for example? Are you seeing any error message on the screen?
The Sky box is designed to get quite warm. You should be able to rest your hand on the top of it.
▪️I AM NOT A SKY EMPLOYEE ▪️
