Discussion topic: picture size is constantly changing
This message was authored by AlanB70 This message was authored by: AlanB70
my sky q box keeps changing the picture size. If I switch off then start again it returns to normal then a short time later it starts changing again
Do I need a replacement box ?
Re: picture size is constantly changing
Hi @AlanB70
