Discussion topic: no wifi on sky q mini box
This message was authored by: stephen+muller
my sky q mini box  doesnt connect to the main sky q  box without me having to  reboot the main box and then it still states theres no internet on the mini box  when i search for recordings on the  mini box theres nothing there can i connect a ethernet cable between my sky q  mini box and my sky q router without it interferring with other wifi products in my house
Re: no wifi on sky q mini box
Hi @stephen+muller
Yes you connect the mini by Ethernet to your main Q box.
Also if you are on Sky Broadband and have the normal black non fibre router you can also connect your mini to that.
Either by WPS or Ethernet.
If you are not on Sky Broadband and you connect your mini by Ethernet to your main Q box it's best to turn off all WiFi on the mini.
Procede as follows
Carry out a network reset on mini in the Mini Home menu with the Ethernet connected. Do not do any WPS and just wait for it to connect.
Once it is connected go immediately into the mini hidden menu  and turn off both bands of WiFi.
Go to Network to turn off both bands of WiFi. Confirm before exit.
Why do you think it might interfere with other wifi devices? Are they using the sky boxes as extenders?
This message was authored by: Lizmayes
My mini box hasn't connected to my main box for three days, now I'm getting upset
@Lizmayes Have you tried rebooting your main Q box ie
then
rebooting your mini box
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
