1
This discussion topic has been answered Discussion topic: next program banner not showing
This message was authored by: Patel5
Just had grade to sky q box. How do you get the now and next program banner on the tv screen?
This message was authored by: nigea99 Answer
Re: next program banner not showing
hi @Patel5
Just press the Enter/select button when watching - this brings up the info banner line where you can scroll right for subsequent programmes.
You can also use the up/down arrows to see other channels or even use the channel numbers to select a specific channel (Setting your most used channels as favourites really helps with this)
hi @Patel5
