Discussion topic: multiroom issues
Message posted on 16 Apr 2025 08:16 PM
multiroom issues
New Sky Q box...well reconditioned....multiroom not connecting and remote now not working for multiroom so unable to set up
Message posted on 16 Apr 2025 08:59 PM
Re: multiroom issues
Hi @SimonLorna
Reset your mini remote by pressing and holding 7 & 9 together on the remote until it’s led flashes four times.
This will set it to infrared which will work all Q boxes. However the remote must be pointed directly at the mini box.
Switch your mini box back on and you then you should be able to complete the Setup
Once you get the mini working make sure that you are pointing your remote at the mini box and press 1 & 3 together until the remote led flashes and follow onscreen instructions to re- pair.
