Discussion topic: multi screan
This message was authored by: loisbell
multi screan
i have a sky mini box and have 2 televisions
i assume that i can watch tv in two seperate rooms,
using to different programs or channels
why do i neeed multiscreen,
i have no desire to watch the same program in seperate rooms
do i need mutisscreen and at what cost?
lois
Re: multi screan
@loisbell
Multiscreen subscriptions are needed as you have a mini box. This allows you to watch Sky via your main box in one room and the other box in another room.
You can have a maximum of 4 mini boxes loaned to you by Sky. You can watch Sky content on two minis and the main box at the same time. You may be able to use a third mini box if the first one in use is being used for a streaming app ie: Netflix or DIsney+.
Be aware the original 1TB (non-UHD) Sky Q box only allows one mini to be in use. To check if you have the non UHD 1TB box check in:-
If it shows as 32Cxxx then you have a non UHD 1TB that only supports 1 active mini box.
All 2TBs and the UHD/HDR 1TB permit two mini boxes. Each mini box which is loaned to you may be subject to a one off upfront charge but you only need one Sky Q monthly Multiscreen subscription.
