Discussion topic: mini Q box
Message posted on 24 Jun 2025 02:31 PM
mini Q box
for 10 days I have been trying to reboot my mini sky box
with no success this has been a regular problem over the
last few months
Message posted on 24 Jun 2025 02:44 PM
Re: mini Q box
Rebbot your broadband first then try reboot of the main Sky Q box, then once that’s back up and running do the same with any mini boxes if applicable -
~ press the 🏠 button
Allow 5-10 minutes before things hopefully revert back to normal.
Message posted on 24 Jun 2025 03:15 PM
Re: mini Q box
last few months
Try a Network Reset on the mini.
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box. If you do this make sure you press the Sky router WPS button and not the router reset button. If you have the new Sky Max router then you need to connect the WPS to the main Q box.
