Discussion topic: leaving sky
This message was authored by: davidk40
leaving sky
is it possible to leave at any time?
Re: leaving sky
@davidk40  If you're in a discounted term, then no as you've agreed to a minimum period (normally 24 months) and Sky won't normally let anyone cancel in this scenario.
Re: leaving sky
@davidk40
With TV subscriptions, if your minimum term has ended you’ll need to give Sky the usual 31 days notice. Be aware that the latest T’s and C’s explicitly state you can’t cancel when still in a minimum term deal unless Sky agree. If they agree you’ll have to pay the remainder of your discounted term.
See the below link
https://www.sky.com/help/your-account/my-account-and-subscription/cancelling/cancel-my-subscription/...
Select ‘No, I still need help’ at the bottom of the link which will lead to contact methods.
(Make sure the flag in the bottom right corner is the correct one ie; UK or ROI).
UK customer ~ It may include a phone number, an email link and also a Message Us option (which is normally available between 9am and 7.30pm).
ROI customer ~ there’s a text option (Monday-Friday 9am to 4:30pm) otherwise it’s only by calling Sky Ireland or writing in.
If you successfully cancel you should receive an acknowledgment email from Sky.
Remember that billing continues through the notice period after which a credit for any overpayment will show on your bills and should be refunded about 6 weeks after your last day of connection.
If you are successful in cancelling Sky Q or Stream return packaging will be sent out near the end of your notice period for any loaned equipment Sky are expecting back. It’s important that you obtain proof of posting and keep it safe and indefinitely.
▪️I AM NOT A SKY EMPLOYEE ▪️
Re: leaving sky
Edited to remove as already answered quicker than I can breathe/type.
