Discussion topic: intermittent lose of connection Sky Q box to minibox
Message posted on 30 Mar 2025 09:35 AM
Sky Q box loses connection to minibox intermittently. Checked settings, wifi and all ok. Problem started after receiving new Sky Hub 4.2
Message posted on 30 Mar 2025 10:37 AM
Re: intermittent lose of connection Sky Q box to minibox
Hi @marmite6
Don't know if that is the Sky max hub. If it is you need to use it like a non Sky broadband router which means that your Mini if using WiFi must connect to the main Q box.
Reboot the mini as above.
You will be asked to press the WPS button on the main Q box (not the mini as the Network reset will start the mini WPS automatically.
Message posted on 30 Mar 2025 10:42 AM
Thank you for your reply. The Sky Q box has recently been re-booted but I will reset the mini and see is that resolves the issue.
