Discussion topic: i have to reset my main skt q box every day
Message posted on 09 Dec 2023 11:06 AM
i have a problem with my main sky q box. every day i have to switch the box off at the mains and reset it, anyone got ideas how to solve this , my 2 mini boxes are fine.
Message posted on 09 Dec 2023 11:16 AM
Re: i have to reset my main skt q box every day
Why do you have to do that?
Hi @Ivor+bigin
First make sure all your Q boxes are on the latest software.
https://www.sky.com/help/articles/updating-sky-box-software.
Also they all need to be in the same Standby Mode.
https://www.sky.com/help/articles/using-the-standby-settings
Once this is confirmed
Message posted on 03 Jun 2024 02:58 PM
Hi. I have to switch my sky q box off at the mains and back on to reset it, because it won't switch on with the remote until I do. Every time. Really annoying. I've done the resets, WiFi is good, changed batteries, nothing has worked. Had this problem for a few weeks now.
Message posted on 08 Jan 2026 07:43 AM
Did you resolve this? I have this everyday
Message posted on 08 Jan 2026 07:47 AM
What time are you having this issue?
Message posted on 08 Jan 2026 07:50 AM
It happens every day when we try to watch tv. It says check the box is plugged in etc...
however all cables are fine, I turn off at the socket and back on. Runs through the startup cycle and then works fine.
Just really annoying and been happening for months
Message posted on 08 Jan 2026 07:54 AM
If it's before 0545 see this link and adjust the settings accordingly
Message posted on 08 Jan 2026 07:57 AM
Yeah I've changed that option a while ago but still doesn't change anything
