Discussion topic: how to link my second hand glass tv to my sky Q box also do I have to keep both remote controllers
Message posted on 01 Feb 2024 12:02 PM
I have difficulty setting up my remote controller I have tried pairing them but when I try and put in the Tv device -(Sky and find my device it can't find my sky glass tv model)
also can I control Sky glass tv and my sky Q box with the same controller?
Message posted on 01 Feb 2024 01:06 PM
Re: how to link my second hand glass tv to my sky Q box also do I have to keep both remote controlle
Have you been through this?
https://www.sky.com/help/articles/connect-q-to-glass
I also note there's a suggested thread that seems relevant at the bottom of this page
Message posted on 02 Feb 2024 11:38 PM
Hi,
thanks for trying to help. Yes I had been through the process but this did not fully work as it kept taking me to link my account with a code number.
I have since called sky and got help with this.
It took some time but it is now fixed.
Message posted on 03 Feb 2024 05:14 PM
Just to give an update- I kept my sky q box as I was on a 18 month contract and it was the better deal than switching to glass tv.
I use my sky q remote for everything except when I turn off my TV because when I use my sky q remote the TV comes back on after about 5 seconds. So I then use my sky glass tv remote to turn off the tv, I make sure I stay clear of the sky q box as otherwise it turns back on and everything starts again 😂.
Nevertheless I am very happy with my TV and sky Q bow.
Also would like to send my appreciation to the sky employee that helped me with this as he was very helpful and patient.⭐️
