Discussion topic: default setting on soundbox
This message was authored by: dave+a31
I have a Sky Q box connected to a Sky (Devialet) soundbar via HDMI cable.   I also have the soundbar set to "Speech", to try to hear the dialogue better.
I set the Audio settings on the Q box to "Normal" for HDMI output.  However, every time I switch it off then on again, it's defaulted to "Dolby Digital", so I then have to go into the settings to set it to "Normal". Every time.
Surely there's a simple fix for this ?
Re: default setting on soundbox
Hi @dave+a31
Certainly shouldn't reset as far as I can see.
Set it to normal and then try a Reset Settings in the Q box hidden menu.  See if that locks it on.
This message was authored by: krg22
@dave+a31
I have exactly the same problem, may I ask if the reset settings worked? Many thanks.
Avatar for dave+a31
Unfortunately not. I have no idea why it does this.
