Discussion topic: connectivity
This message was authored by: KMAC2603
connectivity
My tv says been a problem finding your sky q box on the network.  I have tried everything - changed hdmi cable, switched everything off and on but still comes up with same message.  Sky help absolutely useless.
Re: connectivity
Hi @KMAC2603
Assume this your main Q box?
Try a Network Reset found in main Q box Home - Settings - Setup - Network.
Avatar for KMAC2603
Re: connectivity
All my equipment is sky.  This is for a minibox.  I reset the main sky q box first as this usually rectifies the problem.  We oved tv's around last night and the problem box was working fine.  Just this morning it doesn't.  Have reset every piece of equipment.  It tells me that the problem is with the q box?
This message was authored by: EalingTaz
Re: connectivity
This happened to me too, out the blue. No changes to my setup/network/house/wifi at all and everything fine up til  27 Jan. Then out the blue this connectivity issue continually occuring since 28 Jan across both our mini boxes. I found the main box to be a bit slow and unusual when turning on, did you? Wondering if there's been some upgrade or something that's causing this? Really not techy so find this hugely frustrating!
Re: connectivity
@KMAC2603 @oldfella
This happened to me too, out the blue. No changes to my setup/network/house/wifi at all and everything fine up til  27 Jan. Then out the blue this connectivity issue continually occuring since 28 Jan across both our mini boxes. I found the main box to be a bit slow and unusual when turning on, did you? Wondering if there's been some upgrade or something that's causing this? Really not techy so find this hugely frustrating! Any joy today?
This message was authored by: cuke
Re: connectivity
So have you all powered off your boxes, remove the mains plug for at least 20 secs and then powered back up again starting with the main box?
If there had been any update causing issues then this community would have been awash with complaints but our setup was fine this morning.
Re: connectivity
Do a full factory reset on the mini and re-connect it to the next closest bit of Sky kit using WPS.
Re: connectivity
@EalingTaz  Believe me, if you were techy, you'd probably find it even more frustrating.
