Discussion topic: Youtube slow after pausing.
This message was authored by: welshguy2017
Hi everyone
Anyone else still having problems with Youtube? If you fast forward a video it is slow to restart, it says Loading on the screen.
Re: Youtube slow after pausing.
@welshguy2017
Not since the last YouTube app update in early August (version web_20250805_16RC01).
Does your box have the latest version? Have you tried pan app refresh? Have you power cycled your Q box since getting the issue (unplugged at the mains fora good 5 minutes)?
sky Q 2 TB | sky Q Mini | sky Mobile | EE Full Works FTTC | LG B6 OLED | SONOS Beam 2
Avatar for welshguy2017
Level 3 icon
Hi
How do i update the Youtube App?  i am updating the software now   thanks
You can't update any one app, all you can do is an "apps refresh" and hope it gets updated as part of the process which can take 24 hours.
