3
This discussion topic has been answered Discussion topic: Wrong box
This message was authored by: JaneBellamy
Wrong box
I ordered a new Sky Mini box but received a main Sky Q box didnt realise until we looked how to set it up
Re: Wrong box
@JaneBellamy
You'll need to contact Sky to point out this error and arrange the correct delivery. I'm not sure it's something the Community Messaging Team on here can assist with so give Sky a call.
Re: Wrong box
@JaneBellamy
Avatar for JaneBellamy
Re: Wrong box
Please can someone give a number I can call and speak to a person?!
Re: Wrong box
@JaneBellamy
These are the current methods for contacting Sky, and depending on the issue some will be more appropriate than others …
🟢 📞 Customer Services by dialling 150 (free) from either a Sky mobile or your Sky Talk landline if you have Sky Broadband. The forum doesn’t allow the display of other numbers but official numbers to Sky from the UK are 03 numbers which are usually inclusive from non Sky phones.
All calls will start automated (aka ‘the bot’) which may offer you the online help route or try to send you here to the forum. Stay on the line as long as possible and sometimes saying nothing when asked the reason for the call helps being put in the queue for an agent.
🟢online help via this link
https://www.sky.com/help
🟢Sky Assistant 💬 should also be available via
🟢Social Media You can also get in touch via the messaging services on Facebook or Instagram, (links at the bottom of the forum page).
🟡Note ~ ROI customers If you’re in the ROI make sure the flag in the bottom right of any link is showing the correct flag and change if required. The Sky Ireland phone lines have different operating hours to the UK and are closed at a weekend.
