Discussion topic: Wifi
Message posted on 24 Sep 2024 09:43 PM
Wifi
Hi mini box keeps loosing internet then once connected keeps stopping when on live tv
Message posted on 24 Sep 2024 09:46 PM
Re: Wifi
Hi @Bulldog2019
Reboot the mini as above.
