Discussion topic: Wifi connection keeps failing
This message was authored by: Grumpybampy1964
Hi all, I have sky q, also virgin broadband.  My sky q keeps telling me no Internet connection. However everything else that is connected to the WiFi is still working OK.  Any ideas.  I have tried reseting several times and still the same. Works OK for a short time and the nothing
Re: Wifi connection keeps failing
Hi @Grumpybampy1964
Any chance you connect your Q box by Ethernet to your router?
Avatar for Grumpybampy1964
Did this of that but the main box and router are to far apart
@Grumpybampy1964
Was it working okay previously? Have you made any changes?
I am NOT a Sky Employee
Seems to work OK for a short period. 1 or 2 days then fails. Have to keep re entering the wifi password
