Discussion topic: Wifi connecting another sky network.
Message posted on 21 Nov 2025 08:44 AM
My sky Q box constantly disconnects from my Sky router and when I go to settings its another Sky Wifi address it's trying to connect to. There is 2 Sky networks listed that are showing a full signal availability to connect to but they are not mine! Very frustrating. I dont want to call out an engineer if it is something I can adjust myself. Thanks, any advice is appreciated.🙏🏻
Message posted on 21 Nov 2025 10:55 AM
Re: Wifi connecting another sky network.
Hi @Jake741 You can safely ignore what it says in the connection display, mine is showing a router I stopped using years ago. If you are seeing Skyxxxx then the chances are that they are your own box internal virtual addresses used in its own mesh network.
Message posted on 21 Nov 2025 12:41 PM
Thanks for your reply MightyQuinn, do you know if there is a solution to stop it disconnecting? it really is a pain having to to reconnect daily. Thanks.
Message posted on 21 Nov 2025 05:24 PM
@Jake741 what router do you have the black or the white router
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Message posted on 21 Nov 2025 11:18 PM
Hi, I have the white one,. thanks.
