Discussion topic: WiFi won't stay turned off when ethernet cable isattached
This message was authored by: Sterl
How do you prevent the WiFi turning itself back on when you turn it off in special settings ,turned off both 2.4 and 5 GHz in the advanced settings and confirmed  and then selected connect with ethernet cable . But each time I do it sells ts WiFi.. when I go back to the settings 001 then network.. both 2.4 and 5 are switched back on again.. how can I stop this happening ..as I want to connect via cable only .. please advise Tia
Re: WiFi won't stay turned off when ethernet cable isattached
Hi @Sterl   unlikely I know, but you are selecting Confirm to save the changes?
Avatar for Sterl
Yes I did confirm to save , but just goes back to the same .
Weird. Heard about this happening to others but never figured out why. Mine definitely stays off. Luckily. Got any minis?
Avatar for Sterl
No minis just main sky q box.. tried to do it about 60 plus times
Hi @Sterl
You need to turn off the WiFi immediately after the Q box connects by Ethernet (not before)
