Discussion topic: Why does Sky Sport + keep buffering?
This message was authored by: SteveEdwards1
Continuous buffering on Sky Sports +
Re: Why does Sky Sport + keep buffering?
hi @SteveEdwards1
Do you have any problems when using the other apps like Netflix or Disney +?
Which box do you have ?
If it is 32Cxxx then you have an older 1TB non-UHD Box
If it is 32B0xxx then you have a (V1) UHD but non HDR 2TB Box
If it is 32B1xxx then you have a (V2) UHD HDR 2TB Box (which has a separate Power supply)
If it is 32B2xxx then you have a (V3) UHD HDR 1TB or 2TB Box
