5
This discussion topic has been answered Discussion topic: Where’s my Q box
This message was authored by: Keith174
Where’s my Q box
You came here to install a Q box on 7 October but your engineers ladders would not teach my Sky dish. Your engineer said someone would visit, with longer ladders, but I've heard nothing. What is happening?
Re: Where’s my Q box
@Keith174
As stated above Sky.
These are the current methods for contacting Sky. (Depending on your reason for making contact some methods will be more appropriate than others) …
🟩 📞 Customer Services by dialling 150 (free) from either a Sky mobile or a Sky Talk landline. The forum doesn’t allow the display of other numbers.
All calls will start automated which may offer you the online help route or try to send you here to the forum. Stay on the line as long as possible and saying nothing when asked the reason for the call sometimes helps being put in the queue for an agent.
Note: for any customer whose services are restricted due to a missed payment phone contact is unlikely to work.
🟩 online help via this link
https://www.sky.com/help
🟩 Sky Assistant 💬 should also be available via
🟩 Social Media You can also get in touch via the messaging services on: Facebook, Instagram, or X (links at the bottom of the forum page).
Note ~ ROI customers 🔹If you’re in the ROI make sure the flag in the bottom right of the link is showing the correct flag and change if required. The Sky Ireland phone lines are closed at a weekend.
@Keith174 Afraid you are not contacting Sky's customer services on here, this is a customer to customer forum where customers help each other.
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
@Keith174
Presume you mean 7 September although that was a Sunday?
This is a customer led discussion forum where Sky customers are here to try to help other customers. You aren’t speaking to Sky Customer Services here.
Have you contacted Sky to get an update on your order?
Avatar for Keith174
Level 0 icon
Who should I contact??
@Keith174
Avatar for Keith174
Level 0 icon
Thanks, I understand now.
