Discussion topic: Waiting for prepaid envelope
Message posted on 24 Aug 2023 04:37 PM
Not received any pre paid envelope to return sky multi room box
Message posted on 24 Aug 2023 04:43 PM
Re: Waiting for prepaid envelope
@StuartBebb
If you’ve successfully cancelled Sky should send out returns packaging near the end of the cancellation period, [31 days for Sky Q box(es)], to the address that the subscription was registered at.
Note:~ If you’ve switched from Sky Q to Sky Glass the packaging is usually sent out after 31 days in case you change your mind about Glass.
You can use any packaging as long as it’s secure and you may want to put a note inside with your account number and a list of equipment that is included. This link explains about how to receive an email with your return labels through Royal Mail.
https://www.sky.com/help/articles/return-tv-broadband
If you haven’t anything suitable contact Sky again and see if they’ll re-send. Keep your proof of posting safe and indefinitely and if you use Royal Mail’s collect from home service, keep a record of the tracking number.
