128
This discussion topic is read only This discussion topic has been answered Discussion topic: Sky Q box crashing after the Sky tv adver
Locked
Avatar for Maintenanceman
Level 2 icon
This message was authored by: Maintenanceman
Re: Sky Q box crashing after the Sky tv adver
I have tried the targeted adds solution and so far it's working ok !
Fingers xed it stays this way.
Bit of a bargaining tool for me now as I'm about to renew my Sky contract !
Re: TV is freezing when it gets on commercials, only been since moving to Sky fibre
@NikiW6
Sky Q freezing during adverts is a wider issue already being investigated by Sky.
This message was authored by: Clynt
Freezing
My sky box keeps freezing whilst were watching it
This message was authored by: Mr+Jenzie
the same for me over the last few days, but it was ONLY sky sports news sd, none of the other sky channels, and  not even while watching SSN on sports racing ... yeah a switching issue would cause this, the coding not locking in.  the second time it happened i said exactly this, a switching issue, and probably not realising it was to do with sky adsmart.
would be fascinating to see the glitch in action
This message was authored by: kim+piller
Checked system update and all ok, so why does my Q box keep crashing, fedup with it
Watching a programme,  adverts come on then it crashed. Had to turn everything off twice in a couple of days,  we are both disabled and it difficult keep getting on the floor to unplug and reboot system.  Checked online but says system is all OK. Well it's not all ok
Re: Checked system update and all ok, so why does my Q box keep crashing, fedup with it
@kim+piller
I have moved your post into this thread discussing the freezing issue during certain adverts. As can be seen from the post temporarily marked as the answer Sky are  aware.
This message was authored by: BlueandGold
Happened to me tonight absolute nightmare. For me I think it's something to do with the Animal Control advert which seems to just sit on screen at the end for ages before going back into  Sky One first time I saw it live tonight while waiting for Last Week Tonight to come on forvthe 2nd half and it justbfroze then turned everything off took forever to fix it.
This message was authored by: -teresa-1
Voy ad makes screen freeze
Every time the boy as comes on our screen freezes. When we get away from the frozen as all channels show a blank blue screen. We keep having to unplug and reset.
Re: Voy ad makes screen freeze
It is the VOY ad that seems to cause the problem
@-teresa-1
Thank you
This message was authored by: NiG-GiB
I've just done this to fix this issue. Hope it works.
This message was authored by: Vbrown
Like many, my TV keeps crashing when LNER ad is on, any reason Sky don't remove it?
This message was authored by: Allan95
Posted by a Sky employee
This message was authored by: mr.tickle
@Vbrown Unknown, but instead of persevering with AdSmart which doesn't benefit you when it works, why not just turn it off.
* Go to https://www.sky.com/mydetails/data-and-personalisation
* Scroll down to "Tailored TV Advertising"
* Turn it OFF
* Allow some hours/days for it to take affect
* This is a work-around, not a "fix"
I do not have a sig other than this message. SkyQ.
Enjoying HDR with 4k Blu-Ray, Amazon, YouTube and gaming since 2016.
Locked
Answered - Go to Answer
