Discussion topic: Volume won’t work on my Sky Q
Message posted on 19 Dec 2023 05:22 PM
Hi everyone
I have looked at other discussions on this and followed the steps but the volume button will not work on the remote.
I have tried pressing 7&9 followed by 1&3
then I tried 7&9 then 4&6 and then 1&3
then says setup unsuccessful.
Message posted on 19 Dec 2023 06:15 PM
Re: Volume won’t work on my Sky Q
Hi @Lynn701 Do you have an obscure TV? What is its make and model number. I would carefully follow the set up instructions https://www.sky.com/help/articles/setting-up-q-remote
Message posted on 19 Dec 2023 06:24 PM
Hi @MightyQuinn
I have a Panasonic TV. The link you gave me I have done all that. It's just the volume tbat won't work.
this is the message I get
Message posted on 19 Dec 2023 06:38 PM
Hi @Lynn701 Does it find your exact TV model number?
Message posted on 19 Dec 2023 06:45 PM
It found the model number itself I think @MightyQuinn
I had to get a new sky Q box today because my other one stopped working.
when we first set it up the option did come up to pair the remote. Now when we go on settings and remote control the option to pair isn't there. Just says point your sky Q remote at your box and together press and hold 1 and 3 together.
Message posted on 19 Dec 2023 06:55 PM - last edited: 19 Dec 2023 06:57 PM
Hi @Lynn701 Try pairing through the menu. Home -> Settings-> Remote control. You may have to initialise it first, hold down 7 & 9 until the remote flashes four times. You need line of sight (no obstructions). Note the background should be blue, not grey. Make sure you use "I know it" to input your TV's model number.
Message posted on 19 Dec 2023 07:18 PM
I don't get the option of "I know it"
takes me straight to the picture I sent in my post above.
Message posted on 19 Dec 2023 08:13 PM
Hi @Lynn701 You must initialise the remote (7 & 9, 4 flashes) before each attempt. Failing that, power reboot the box.
Message posted on 23 Feb 2026 08:48 AM
Lynn 701 did you get your problem solved with your volume. I Have the identical same problem since changing my broadband supplier. I can't get to the menu allowing me to select TV model. This is my bedroom TV.
Message posted on 23 Feb 2026 02:20 PM
