Discussion topic: Volume Control not working on SkyQ remote
Message posted on 20 Nov 2023 09:46 AM
My volume control has stopped workoing on my SkyQ remote. All the other controls are working. I've tried resetting the control but it makes no difference.
Message posted on 20 Nov 2023 10:01 AM
Re: Volume Control not working on SkyQ remote
Have you configured it to your make/model of TV?
Message posted on 20 Nov 2023 10:16 AM
I've sought to do that but it doesn't work and then says my TV is not supported. It's worked fine since set up a couple of years back.
Message posted on 20 Nov 2023 10:17 AM
Hi PANDJ2020 - thanks for trying to help - much appreciated.
Message posted on 20 Nov 2023 11:18 AM
@Chris218 what make and model is your TV?
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Message posted on 20 Nov 2023 11:57 AM
Hi Laing1 - It's a Samsung QE65Q65TAU - maybe 3 years old but it's not in the list shown on Sky.
Thanks for trying to help.
Message posted on 20 Nov 2023 12:16 PM
@Chris218 when you are trying find your model have you tried find it for me then tried all of the options that appears
Message posted on 20 Nov 2023 12:50 PM
Hi again Laing1 - yes, I've tried that but it then says my TV is not supported - of course it was working fine until last night.
Message posted on 20 Nov 2023 01:55 PM
@Chris218 so when you do find it for me none of the 8 options work ?
Message posted on 20 Nov 2023 03:31 PM
Hi, yes none of the options work. I've now spoken to Sky and they are sending a new control.
