Discussion topic: Viewing card
Message posted on 08 Aug 2026 03:15 PM
Viewing card
It's says insert your viewing card and it's in the box but not working
Message posted on 08 Aug 2026 03:30 PM
Re: Viewing card
@Gill196 try taking the card out giving the chip a clean with a soft cloth the re-inserting the card pushing it in firmly until it clicks
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Message posted on 08 Aug 2026 03:31 PM
Re: Viewing card
@Gill196 wrote:It's says insert your viewing card and it's in the box but not working
Often this is solved by taking the card out, making sure the chip is clean with a lint free cloth and sited correctly (i.e. pushed in properly).
A power cycle of the box itself (unplug at the mains for 5 minutes) can also help.
If you still have issues, go to Home > Settings > System info, highlight your Viewing card number, select Setup on the right side, and choose the option to trigger a callback/refresh.
