Discussion topic: Viewing card
This message was authored by: Seanclayton
Viewing card
Says please insert viewing card with chip facing up. I've tried inserting both up and down but still same message
Re: Viewing card
Hi @Seanclayton
First check that your viewing card is correctly inserted. Viewing card is in the right hand end of the box.
If it is in correctly there is not enough of it sticking out to grip and remove it.
Push it fully in and it will pop out slightly enough so you can remove it.
Take it out and give the chip a gentle wipe with a damp lint free cloth or E-cloth.
Ensure that it completely dry before you reinsert it chip side up and chip end in first. Push it gently fully in and you should feel a slight click when it is engaged. If it has popped out enough to remove it is not located correctly.
If you are satisfied that it is in correctly
Try refreshing your Viewing card.
Home - Settings - System info.
Highlight Viewing card number and then select Setup on the right hand side.
Then select Use this option to trigger a callback
No call is actually made but the Viewing card should be refreshed.
Avatar for Seanclayton
Level 0 icon
Re: Viewing card
Card doesn't stay in. When pushed in it pops out by about a cm. Enough to get hold of
Re: Viewing card
Hi @Seanclayton
You are possibly pushing it in too firmly.
As per my post
