Discussion topic: Viewing Card Issue
Message posted on 05 Dec 2023 03:10 PM
Viewing Card Issue
Hi received a replacement Sky Q main box today as previous one developed a fault. Set it up and tried everything but it just won't recognise viewing card. Just says please insert viewing card and I cannot get past it. Help please will it be a replacement viewing card?
Message posted on 05 Dec 2023 04:37 PM
Re: Viewing Card Issue
@PW0407 You could try refreshing your viewing card by pressing home > settings > system info > viewing card number > setup > viewing card setup press select to trigger a callback don't worry nothing to do with your phone its only Sky's terminology this will be done over the internet
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Message posted on 05 Dec 2023 05:48 PM
Hi
thanks for your suggestion I'll give it a try.
I've spoken to customer services and we did some troubleshooting and they are sending me a viewing card so hopefully I'll be sorted when that arrives if not before.
