Discussion topic: Using two remotes
Message posted on 27 Mar 2025 04:21 PM
Using two remotes
Can you use two voice remotes at the same time
Message posted on 27 Mar 2025 04:31 PM - last edited: 27 Mar 2025 04:33 PM
Re: Using two remotes
hi @GPARR
unfortunately not 2 for voice control
You can have one in bluetooth mode & thus able to use voice control & another (or more) in Infared only mode (no voice control)
So , as I say, only one can be paired in bluetooth mode (& thus Voice control) - the other(s) has/have to be IR only
To do this :
You first pair the one(s) you want to use in infrared only mode (pressing & holding 7 & 9 if needed to reset) by pressing & holding 1 & 3 together & following the on screen instructions
Once paired to the box & TV you reset it to use Infrared by pressing & holding 4 & 6 together
Then you re-pair the one you want to use in bluetooth mode & for voice contro, as above but this time don't press the 4 & 6 after
Message posted on 27 Mar 2025 05:13 PM
Thank you, that was very helpful, I now know how to achieve dual control.
