Discussion topic: Using 5GHz Mesh with Non Sky ISP
Locked
This message was authored by bob1234 This message was authored by: bob1234
Re: Using 5GHz Mesh with Non Sky ISP
@GazeruthThat is not actually true with the latest Q update you can now use Q boxes as hot points even if you don't have Sky broadband.
Go into settings > network > advanced settings and you can turn it on.
This message was authored by Gazeruth This message was authored by: Gazeruth
@bob1234 Just checking on the Sky Q main box and Mini boxes - the only option I have in Advanced Settings is to set a manual IP address rather than get an allocated one - is there a newer version of the software on the boxes I need to download?
ukhardy071
This message was authored by ukhardy071 This message was authored by: ukhardy071
It doesn't enable 5GHz hotspot (per my title) just 2.4GHz. With 2.4G boosters I have pings of 1000ms or higher, and speeds that are pretty abysmal. They give me 6ms ping and 73Mbps on 5GHz which sky do not natively support hence I posted this. No issues to date.
Locked
