Discussion topic: Upstairs mini box no longer showing sky programs
Message posted on 08 Apr 2025 10:37 AM
Our main sky box is downstairs in our main room and works fine. Our mini box is upstairs and until recently was working fine. We can watch netflix and prime video upstairs but can no longer access sky programs. We have tried resetting everyting including turning everything off but to no avail. However, on one occasion after turning everything off and back on, we did receive sky programs for about 20 seconds before it disappeared again. We do have a multi room subscription so not sure what we are doing wrong?
Message posted on 08 Apr 2025 10:53 AM
Re: Upstairs mini box no longer showing sky programs
Hi @wills7499
Try a Network Reset on the mini.
