Discussion topic: Updated package, still have old Sky Q box; how do I return it?
Message posted on 11 Jan 2024 02:57 PM
I moved home and upgraded my package at the same time to 2 TB Sky Q box and mini box. Installation done by a contractor, not a Sky engineer. They didn't take old Sky Q 1 TB box. How do I return it to Sky?
Message posted on 11 Jan 2024 03:20 PM
Re: Updated package, still have old Sky Q box; how do I return it?
Normally we would probably just refer you to the standard returns link but this is outside the normal process so I have escalated your post to a SKY support team, who, hopefully, will be in touch.
They should be able to advise the correct way forward.
Please see this link re the escalation and what you might see:
If you are using Safari I believe you must make sure that 'Hide IP address' is not checked in settings to be able to see it - if you have difficulty finding that setting then may be try accessing here with another browser
Message posted on 11 Jan 2024 03:22 PM
Hi there! Thank you for escalating this. However on this occasion it would be best to talk to our Home Move and our Downgrades team, as they are the ones with relevant authority on this matter. Please call our team for further help.
Thanks.
