Discussion topic: Unable to get catch up / on demand on mini box.
This message was authored by: Pamelajane
Hello, I have a mini box linked to main Sky q box. On the mini, I can access TV guide and watch all channels,  and see recordings, but when I select catch up, on demand services, apps, etc, it says there is no internet connection. In settings on the mini box under network connections, there are ticks against connection to broadband router and connection to network. I have tried switching off router, switching off main sky q box and mini box but nothing has worked. Anyone able to help with any suggestions? TIA
Re: Unable to get catch up / on demand on mini box.
Hi @Pamelajane
Try a Network Reset on the mini.
Avatar for Pamelajane
Hi @oldfella , thanks for your reply. Sorry,  should have mentioned that I've tried doing the reset this way as well with no success. Catch up, on demand, etc is all working perfectly fine on the main box, just not on the mini.
hi @Pamelajane
When you did the Network reset on the mini was the WPS light flashing on the mini?
If so did you press the WPS button on the main Q box within two minutes?
Will try again as maybe I didn't do it correctly. It's actually for my elderly dad and he's now watching football so will have to wait for an appropriate opportunity later on!!
Hi @Pamelajane
Another thing to be aware of is to make sure that he is not trying to Download UHD on the mini as minis are not UHD capable.
