Discussion topic: Unable to fast forward
Message posted on ‎13 Aug 2024 09:45 PM
Why can't I fast forward on my recordings I can rewind but not forwards. I have tried to reboot Sky Q but no difference I have also rebooted remote with sky box. Last night while trying to fast forward the screen went black but after rebooting it was fine, fast forward has worked all day and early evening then suddenly stopped.
Message posted on ‎13 Aug 2024 09:50 PM
Re: Unable to fast forward
Hi @Juliep60
You could check your disc space in Recordings - Manage to make sure you are not near full capacity.
Otherwise you could try a Reset Settings in the Q box hidden menu.
