Discussion topic: Unable to change channels, Sky Q +mini box. Picture is freezing.
This message was authored by: ronnee
Both main Sky Q box and mini box have same issues.  Both unplugged and restarted but issue remains.  Playback on mini box kept freezing yesterday, all channels. Today, unable to change channels on main TV, screen goes blank and then sometimes randomly opens up
on random channel.
Re: Unable to change channels, Sky Q +mini box. Picture is freezing.
on random channel.
Hi @ronnee
Try a Reset Settings in the main Q box hidden menu.
Once the main Q box is back up and running
Reboot the mini as above.
You will be asked to press the WPS button on the main Q box (not the mini).
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box
