Discussion topic: Ultra Hd issues
This message was authored by: confusedman
Ultra Hd issues
I have had my sky q box connected to my ultra Hd tv for approx two years but occasionally I get error saying it can't detect an ultra Hd tv with error code UH001 . I have been able to change this previously back to ultra Hd but this time it isn't and keeps going back to 1080.
I have a Samsung tv, any ideas on what could be causing this and how to stop it would be appreciated
Re: Ultra Hd issues
What HDMI cable are you using?
Avatar for confusedman
Re: Ultra Hd issues
Using cable that came with sky q box, same cable as was connected yesterday when it was working fine, nothing has changed connection wise
Re: Ultra Hd issues
Have you got another cable to try?  Ensure they are fully seated.
(Has the TV been 'rebooted'?)
Re: Ultra Hd issues
I've done nothing apart from reset tv and it has now connected as ultra Hd! Not sure if the issue is with tv or sky Q box but very frustrating when it happens 😩
Re: Ultra Hd issues
TV's aren't 'dumb' any more.  They have complicated software (firmware), settings and memory buffers etc.  A 'reboot' of a TV is sometimes required, just like the Q box...
