Discussion topic: Ultra HD MYSKY_1999
Message posted on 11 Mar 2024 08:46 AM
Ultra HD MYSKY_1999
I am trying t download ultra HD on my SKY Q box but it keeps coming up with this error message, MYSKY_1999. Can anyone help? Its frustrating you cant talk to anyone or go online chat.
Message posted on 11 Mar 2024 09:54 AM
Re: Ultra HD MYSKY_1999
Check that your Q box is still set to output 2160P on the video settings.
Is your UHD add-on still active on your subscription?
Also try rebooting your box by turning it off at the wall for a minute or two then power it back on. A reboot sometimes helps clear such issues.
Message posted on 11 Mar 2024 10:50 AM
thank you. I will try this. I am trying to subscribe to it through MySky on the TV and it isnt working. SO I have no subscription but trying to add it on.
Message posted on 11 Mar 2024 11:03 AM
Best option when upgrading is speak to Sky directly.
Firstly some upgrades are not available online and secondly you may be able to negotiate a deal.
If you need to contact them you need to persevere by phone.
To contact Sky
Select Need more help
at the bottom of the following link and this will lead to a phone contact.
Ignore all automated messages and wait for an agent
https://www.sky.com/help/home
Message posted on 01 Sep 2024 02:32 PM
I called and was told I couldn't update mine as mine was a 1tb Q box and its only supported through a 2tb box - and £99 to upgrade the box
Message posted on 01 Sep 2024 02:49 PM
Hi @Martyn+Jones The important thing is the hardware version. It sounds like you have a 32Cxxx box. The latest 1TB box, 32B2xx supports UHD & HDR. So the advisor was mistaken, it is not just the 2TB box.
