Discussion topic: Uhd quality
This message was authored by: Tjb25
Uhd quality
The last 3 nights 406vfor tge darts the uhd quality is very poor. Particularly from one certain camera angle
Re: Uhd quality
@Tjb25
I've been watching over the last 3 days on Q and can't see any issues personally, what is poor about it to you? How does it look in HD on channel 857? Still a problem with the same camera angle?
This message was authored by: gems1979
Re: Uhd quality
I agree, shocking quality, especially the close up of the board. It looks patchy/fuzzy.
This message was authored by: CookGeorge85
Re: Uhd quality
Same here I have the 55inch sky glass and the pic quality on the UHD for the darts is absolutely shocking. Like watching a VHS from the 90s? What's going on?
Re: Uhd quality
There's been no issues over satellite - I presume this is via streaming.  Quality dependent on a number of factors (it will drop to maintain a picture)
This message was authored by: F1_2025
Re: Uhd quality
I'm having exactly the same problem. It's very grainy especially on the black so I've not encountered this yet else having a Sky Go for the past six months. I've only noticed that the past couple of days whilst watching the darts.
has anyone called Sky?
