5
This discussion topic has been answered Discussion topic: UKTV access
This message was authored by: Christine191
UKTV access
Hi. Should it be possible to access UKTV on my Sky Q TV? If so, could someone direct me to it. Thanks.
Re: UKTV access
Hi @Christine191
Check the Catch up TV section of the Q box..
All Channel tab shows UK TV play.
Re: UKTV access
Hi @Christine191
Re: UKTV access
Hi @Christine191
hi @Christine191
in addition to the UKTV section in Catch up there are also the pay channels from UKTV (i.e. Alibi & Gold)
you can also find more in the On Demand section - Channels
In this section they are all under the individual channels (alibi, Gold, Dave, W & Drama)
Avatar for Christine191
Level 2 icon
Re: UKTV access
@oldfella
Many thanks for the advice. I've now found the programme I was looking for.
Level 2 icon
Re: UKTV access
@nigea99
Thank you very much for your help. I've now found the programme I was looking for.
Re: UKTV access
@nigea99
Glad you have found it.
Don't forget that Voice search (or even manual seach using the magnifying glass button) is an alternative way of finding specific  programmes (although I have known Voice search occasionally to be not 100% reliable)
