Discussion topic: UHD Downloads
This message was authored by: careilly
UHD Downloads
Hi, I can watch UHD live, but I am unable to download UHD content. I get an error message saying I need to upgrade my subscription.
Re: UHD Downloads
Hi @careilly
Assume you have the add on UHD subscription.
Do you have a relevant subscription also for the content?
ie
Sky Sports?
Sky Cinema?
Avatar for careilly
Re: UHD Downloads
Hi, I have all the relevant subscriptions, UHD and sports/cinema. I have also checked downloads are set to UHD in settings.
Re: UHD Downloads
Hi @careilly
Have you tried rebooting your Q box?
Avatar for careilly
Re: UHD Downloads
I've tried rebooting, but that didn't work.
Re: UHD Downloads
Hi @careilly
Ars you sure your Q box is set to 2160p resolution?
If you are also trying to view UHD/HDR then you need 2160p 10 bit
Avatar for careilly
Re: UHD Downloads
Hi Oldfella, thanks for the help. box is set up for 2260p UHD. I've also tried resetting the viewing card.
Re: UHD Downloads
Yes @careilly
But is that 2160p 10 bit or 8 bit?
Avatar for careilly
Re: UHD Downloads
10 bit
This message was authored by: tunneltiger
Re: UHD Downloads
I had this issue a few months ago,  I emailed Sky  viewer relations  and they reset something sky end(they said support team) and a few hours later I had UHD available as downloads again
Avatar for careilly
Re: UHD Downloads
Do you have their email address please?
Re: UHD Downloads
