Discussion topic: Tv
Message posted on 01 Jun 2024 08:52 PM
Tv
Signal keeps going
Message posted on 01 Jun 2024 08:54 PM
Re: Tv
@Dave89 wrote:
Signal keeps going
@Dave89
If you’re seeing a message displaying ”No signal” it tends to be from your TV, such as possibly not being on the correct input (check the HDMI cable between the Sky Q box and your TV)
Whenever a “no satellite signal” message is displayed, that relates to your Sky Q box, so firstly check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Also check out the troubleshooting on this link
It may then give you the opportunity to arrange an engineer to check the alignment of your dish.
A misalignment is not necessarily something that will be visible to the naked eye and could only affect one or two channels. If you’re on a communal dish you’ll need to liaise with your landlord or building management company who deal directly with their approved engineers.
