2
This discussion topic has been answered Discussion topic: Tv
This message was authored by: bingbong17
Tv
Tv keeps losing picture every 1 minute started 2 days ago
Re: Tv
Hi @bingbong17
Assume this is your Q box.
Re: Tv
Hi @bingbong17
Avatar for bingbong17
Re: Tv
@oldfellaill try in morning linked to sky mini box in an annex thanks for your help 👍🏻
