Discussion topic: Tv won’t work
This message was authored by: Cath_sayer
Tv won’t work
Tv will connect to Wi-Fi but not to the server
Re: Tv won’t work
@Cath_sayer  You say TV, do you mean your Sky Q box, what happens when you watch On demand content?
Avatar for Cath_sayer
Level 0 icon
Re: Tv won’t work
Says there is no satellite signal so nothing is working
Re: Tv won’t work
@Cath_sayer  If you work through the link below and go through to the end if the issue isn't resolved you should be able to book an engineer.
https://www.sky.com/help/home/sky-tv/sky-tv-q/fixing-sky-q/fixing-live-tv/no-satellite-signal/articl...
