This discussion topic has been answered Discussion topic: Tv speech really quick like always fast forwarding
Message posted on 18 Jul 2025 07:48 PM
New sky q box, set it all up fine, but all channels picture is fine but speech is super fast
Message posted on 18 Jul 2025 09:28 PM
@kimfox wrote:
Thank you, it's my elderly parents Sky, so will try this tomorrow
Hi @kimfox
Try the reboot first.
Message posted on 18 Jul 2025 08:53 PM
Re: Tv speech really quick like always fast forwarding
Hi @kimfox
If a reboot doesn't fix it try a Reset Settings in the Q box hidden menu.
Message posted on 18 Jul 2025 09:04 PM
Hi @kimfox
Message posted on 19 Jul 2025 10:04 AM
Doesn't that mean that the audio gets increasingly far ahead of the video??
Message posted on 19 Jul 2025 11:24 AM
Thank you everyone this is now resolved
Message posted on 19 Jul 2025 01:07 PM
Do you mind sharing how you fixed it / what it was, in case others search for the same symptoms?
