Discussion topic: Tv not working
This message was authored by: CJ20
Tv not working
on all my Sky q mini boxes I get an error message which says "Please check your subscription entitles you to view this channel". I have an active sky multiroom subscription. I have tried restarts and resets but nothing helps.
Re: Tv not working
Hi @CJ20
Have you carried out a Reset Settings on the main Q box?
Reset Settings in the main Q box hidden menu.
