Discussion topic: Tv issues recording
Message posted on 31 May 2025 11:01 AM
Tv issues recording
Has anyone had issues with recording programmes as even when I have programmes on series record they sometimes don't record and I don't understand why so has anyone had same issue?
Message posted on 31 May 2025 12:19 PM
Re: Tv issues recording
Hi @Bigemma
The majority of series link failures or repeats are normally down to the Host Broadcaster coding incorrect link information. Main line channels however don't often make mistakes.
You could try the following procedure.
First make a note of all your series links in ~Recordings - Scheduled.
Then first remove just the series link from each scheduled recording. ( Don't remove or cancel the recording at this stage, just remove the series link)
After you have removed all the series links then Cancel every scheduled recording.
Once the scheduled section is completely empty reboot the Q box.
Once the box is completely back up and running re add all your series links.
See how it goes.
