Discussion topic: Turn off pin protected programms
Message posted on 16 Jun 2025 05:45 PM
Re: Turn off pin protected programms
@Sleepybint wrote:This exactly
never used to pop up on crime channel now it does
everything I'd set to off
"What" exactly? Just set your pin to something simple like '1111'. People moaning about entering a simple 4 digit number...... I'll stop there!
Message posted on 16 Jun 2025 06:02 PM
It's not about having a simple pin, it's about wanting to let something run in the background that has been recorded - an 18+ boxset for instance. It's ridiculous that Sky make you enter your pin after each episode. You had no need to comment there at all
Message posted on 16 Jun 2025 07:29 PM
@KT140486 It's bit Sky making you enter it, they have to follow the rules set by OfCom.
Message posted on 16 Jun 2025 07:36 PM - last edited: 16 Jun 2025 07:37 PM
Presumably the channel is now carrying content which requires Mandatory Daytime Protection: this would give them access to a much wider range of programmes to fill their schedule.
Message posted on 16 Jun 2025 11:13 PM
@KT140486 wrote:It's not about having a simple pin, it's about wanting to let something run in the background that has been recorded - an 18+ boxset for instance. It's ridiculous that Sky make you enter your pin after each episode. You had no need to comment there at all
My suggestion was a valid one that reduces the "pain" of entering 4 digits to allow you to watch a channel that has had a level of control added to it due the 'law of the land' that Sky are forces to adhere to. It's a first world problem that for some reason gets people's backs up & I just don't understand why.
Message posted on 17 Jun 2025 11:17 AM
I wasn't complaining about entering a "simple pin" and I don’t need to change it
I literally moved home and suddenly it pops up on every program even tho it's all switched to off
Message posted on 17 Jun 2025 11:20 AM
Yeah I had considered this but it's all the time not just those times , and the shows are the same ones it reruns all the time too 🤷🏻♀️
Message posted on 17 Jun 2025 11:25 AM
@Sleepybint
Moving home will not have influenced this.
Message posted on 17 Jun 2025 02:48 PM
@Daniel0210 wrote:
@Sleepybint
I literally moved home and suddenly it pops upMoving home will not have influenced this.
Well yes I did assume that
I was just stating that that is when it changed 👀
Message posted on 08 Nov 2025 07:43 PM
Bloody stupid that you have to put the pin in for every pin protected channel, once put in it should cover all channels!
Message posted on 09 Nov 2025 09:10 AM - last edited: 09 Nov 2025 10:06 AM
Mandatory PIN
A compulsory audience protection tool for
consumers to restrict access to unsuitable
content. This tool cannot be removed by the user and requires a PIN (personal information number) to be entered each time the user accesses the content. The PIN must be chosen by the account holder and allows only those authorised to view the content.
https://share.google/BTU4XRIuXmykTmsjZ
Mandatory Daytime Protection is ultimately a political creation and would require political intervention to be revised.
Message posted on 07 Feb 2026 12:57 PM
Nonsense, I can watch the same programme / episode on other channels without this government control. Answer that please?
Message posted on 07 Feb 2026 01:06 PM - last edited: 07 Feb 2026 01:29 PM
@Mc0847 wrote:Nonsense, I can watch the same programme / episode on other channels without this government control. Answer that please?
Which programme and which channels? It's normal for something that requires a PIN on Sky or Virgin to be available without a PIN on Netflix/Amazon/Disney etc, as broadcast platforms are subject to more regulation than streaming platforms.
Message posted on 07 Feb 2026 01:21 PM - last edited: 07 Feb 2026 01:28 PM
All broadcast (live EPG) channels have the same restriction: most simply don't carry such content before 21:00
Ofcom fines for not applying Mandatory Daytime Protection correctly are severe, and a repeat offender would ultimately face losing its UK broadcast licence.
There's inevitably a degree of variation: sometimes content is edited to remove problematic material, for example, and occasionally the PIN control is misapplied.
Message posted on 07 Feb 2026 01:36 PM
@nigea99 wrote:
@afsgdterfw wrote:Turn off PIN protected shows
When SKY Atlantic & other channels show certain material before the relevant 'watershed' it will always be present & you cannot turn it off
https://helpforum.sky.com/t5/Sky-TV/Is-there-any-way-I-can-turn-this-damn-parental-control-off/ba-p/...
Do check that all the relevant options in Parental Controls are appropriately set but as I say you may need it for some
Our advice is to set the PIN to something like 1111 to help enter it when needed
The stange thing is yes on Sky you must have a pin to view adult material before watershed however I have now tv for sky cinema showing the same live films channels as Sky Q and stream and I can view all without any pin what so ever. I just tried it I am watching trading places which certificate 15 and it came on no pin required. Ovaasly ofcom rules do not apply to now tv
