Discussion topic: Trouble with recording
This message was authored by: Comrie74
Hi iv been having trouble with my sky, can i have an engineering come out, iv done the swithing o and back on mig its still not working, the recording is the trouble
zoie
Avatar for Comrie74
Re: Trouble with recording
 this is what i get when trying to watch what iv tecorded
zoie
Hi @Comrie74
Afraid you are not contacting Sky directly here as this is a customer forum.
If you need to contact them you need to persevere by phone.
To contact Sky
Select Need more help
at the bottom of the following link and this will lead to a phone contact.
https://www.sky.com/help/home
Regarding your issue
This message was authored by: nolte
If you try to pause or rewind live tv, does it come up as "hard drive error"
ROI sky Q Customer.
