Discussion topic: Totally disconnect Bluetooth remote
Message posted on 30 May 2023 01:06 PM
I want to disconnect my Bluetooth remote from my TB box so i can reconnect to one of my Q boxes. How do it do this? I have tried with the 7 and 9, but it does not flash four times only once.
Message posted on 30 May 2023 01:15 PM
Re: Totally disconnect Bluetooth remote
Hi @miv
No need to disconnect it.
Pairing again to another Q box will override the setting.
To completely reset your Bluetooth remote.
Then make sure that you are pointing your remote at the Q box and press 1 & 3 together until the led flashes and follow onscreen instructions to re- pair.
