6
This discussion topic has been answered Discussion topic: Toob router connection dropping
This message was authored by: Nick5691
Hi I have had little luck within Toob community so was hoping to find solution here.I have switched from Virgin to Toob over 3 months ago and have found my sky box constantly dropping its connection with the router.This happens with Wi-Fi and Ethernet connections.I  know router still operating fine as all other connections remain.Tied all obvious solutions like rebooting but still happening
Virgin never had this issue
Re: Toob router connection dropping
Hi @Nick5691
If you connect the main Q box by Ethernet then it is better to turn off the Q box WiFi.
You cannot do this however if you need WiFi for a Mini unless all boxes are connected to your router by Ethernet.
Start with main Q box and first carry out a Network reset with the Ethernet connected.
Highlight Status and then select Reset on the right hand side. Select connect wired to non Sky Router . Do not carry out any WPS and just wait for the box to connect. It may take a couple of minutes. If it does not connect there is an issue with the Ethernet connection.
As soon as it connects go into the Q box hidden menu and turn off WiFi.
Go to Network to turn off both bands of WiFi. Confirm before exit.
Repeat the network reset on any minis in the Mini Home menu with the Ethernet connected. Again do not do any WPS and just wait for it to connect.
Once it is connected go into the mini hidden menu (same procedure as above) and turn off both bands of WiFi. Confirm before exit.
Turned wifi off when testing ethernet?
Hi @Nick5691
Avatar for Nick5691
Thanks I have given this a go and connection still holding
Great. Did you use ethernet or wifi?
Avatar for Nick5691
Ethernet cable and still going Thanks
This message was authored by: Madmalk
Hi Oldfella I have a toob router in our 3rd bedroom/office it is connected to  PC via ethernet cable. All our other devices work very well, Smart TV.. Panasonic , mobile phones, laptops, tablets. The router averages 900 plus Mbps, Sky Q however is continuously dropping  out or looping roughly every 8 minutes making watching anything streaming frustrating and annoying. This should be a enjoyable experience...it is anything but. Any help greatly appreciated.
